Grimec Mc With Ajp 4 Piston?
Can you run an AJP 4 piston caliper with a Gremeca front master cylinder? Are there any issues with this? The bike is a 1999 315.
As long as the caliper mounts properly in relation to the disk, it should be OK.
Going from 2 to 4 piston has been a pretty common mod (I did it on an '01 Sherco), and the master cylinders seem to push enough fluid.
From memory its perfect, fits straight on no bother. Use the AJP caliper, don't use Hebo, brake line does fit so well.
This sounds like a good mod,where can I find a 4 pot AJP front caliper and what's the damage
Hey ''GSA'' are those your initials or are you the owner of a BMW Adventure ;):D
Hey ''GSA'' are those your initials or are you the owner of a BMW Adventure  :o  ;)
;) You got me!
GS Adventure owner
Alias 2 Wheel Humvee on the other forums ;)
I've answered my own question regarding the caliper by phoning BVM,about
Hi, 100 Pounds is much to expensive -
the AJP 4 Piston Caliper only costs 75 € (plus Pads) at TOPFUN in Spain. I'v got mine for 70 € from the Austrian Montesa Distributor.
But now its to late, you've already bought one.
Greetings from Austria
michael
Link to item
Edited by t_wimp
