February 14, 201115 yr Yes, the clutch arm has been extended - the standard one is in one piece. The clutch is excellent on these - strong, light and lasts for ages. The additional spring shouldn't be needed - I would think doing what you suggest with the standard spring should do it. If it needs more than the original spring there is something wrong. There is no harm in extending the clutch arm by this amount, and if the cable is well lubed, has a clean run and the clutch lever and bracket are in good condition, the clutch should be very light. Good luck with it - they are great bikes - Alan
February 16, 201115 yr Author Thanks for the comments, will try it as is and see how it goes. Will have to experiment with the spring I guess... Going to order up a new cable anyway as the one here is shot, how about this?: http://www.tytrials.co.uk/trailandtrialsuk/prod_43349--13-Venhill-Clutch-Cable-TY250-amp-TY350-Mono.html
February 20, 201115 yr Thanks for the comments, will try it as is and see how it goes. Will have to experiment with the spring I guess... Going to order up a new cable anyway as the one here is shot, how about this?: http://www.tytrials.co.uk/trailandtrialsuk/prod_43349--13-Venhill-Clutch-Cable-TY250-amp-TY350-Mono.html I just bought a new cable from ABV Motorsport on Ebay (item number 180487505046) it arrived after 2 days and is a Venhill cable , fitted striaght on no problems , i did buy a gasket from TYTrials and had no problem with them . Shaun .
February 21, 201115 yr 18+ Quid... eeeek I think I've got some new original yam cables... I'll check my 'misc' box.
February 21, 201115 yr Don't get mixed up with 'misc - jazz mags' or you might be there for a while No the misc jazz mags are still at your house... remember that you borrowed them for some ahem 'research' No clutch cable... just throttle cable and front brake hose (and a TYZ rear brake hose)plus some other misc ! Shedco had all the good stuff
February 21, 201115 yr Just checked and i only have a new superlight clutch cable for the TY250 twinshock. Sorry. Oh yes no jazz mags either. Edited February 21, 201115 yr by Old trials fanatic
February 23, 201115 yr Got mine from JK Hirst. Original Venhill Superlight .......... and it IS! Never heard of that magazine. .. oh are you on about the cable
