fly-wheel gasket help!
hi everyone
had a wet practice trial today got home and cleaned my bike down and started it up and then water started blowing out through the gasket when it was running stopped the bike and toke the flywheel cover off and there was dirty water in there is this a major problem or just a gasket?
if just a gasket where can i get one from?
cheers for any advice
andy
just clean it and let it dry out. gas gas recomend a 6mm hole in bottom of cover to let water out.put cover back on with a little mastik or a gasket from gas gas uk.
A small amount of Mastic could be better as the plastic flywheel covers distort when tightened up. The gasket on mine is only sealing around the bolts.
