March 1, 201115 yr Can anyone help. My fork seals need replacing and I'm not sure how much oil I need 2 put in each fork and what is the best oil to use. It's a gas gas jtx 96 model. Thanks
March 1, 201115 yr Can anyone help. My fork seals need replacing and I'm not sure how much oil I need 2 put in each fork and what is the best oil to use. It's a gas gas jtx 96 model. Thanks After fully draining the forks, each side takes 300cc's of 5-weight fork oil. The 96' forks do not seem to be particular as to any certain brand, just be sure it's regular fork oil (not motor oil, for instance) and you should be fine. Jon
