crank case breather pipe
Hi folks, I have a GG TXT PRO 250 2005,I've just got the bike so I am giving it a good service making sure it has oil & greese where it should, the crank case breather is perished & I think it is shorter than I would expect it to be. the question is when I fit a new pipe where should it be routed to ? do people just hang them down under the bike or some place else ?
The pipe should go straight up and then loop over, then zip-tie it to the frame near the upper shock mounting.
It will vent but should'nt let water in.
