2006 GAS GAS 250PRO MAP SWITCH
I JUST GOT A 2006 250PRO, IT IS MISSING THE MAP SWITCH ,I HAVE A NEW ONE BUT WHICH WIRES DOES IT PLUG INTO,AND DO I NEED TO REMOVE THE TANK? THANKS.
you will have to take of the tank.there will be two wires not getting used coming out of the cdi unit , one male the other female ends.just plug them into map wires and thats it.
Thank you! Rich
Two wires, one Orange and one black.
They can be joined together, If so separate them and connect the wires from the Map switch
