TXT 300 Wheel Bearings
Can anybody provide me with the replacement codes for the front and rear wheel bearings for my TXT pro 300
Manual says Rear C160001
Front ME120136055
Thanks Gents
Front ME120136055
Thanks Gents
I think the rear is the 6004-2RS bearing and the front is 6095RS. You didn't mention what year your bike was
but the front bearing you mention is for the Marzocchi type fork, with the larger OD axle than the earlier GG ones.
Jon
Jon
Alternatively measure (ruler will do) outside diameter, inside diameter and the thickness. My local agricultural spares place has always found what I wnated and its heaps cheaper than a specialist trials shop. I've also used simplybearings website which is dead easy to use as well.
Pro mmodels are;
Front SKF 61905 2RS 'H' size 25x42x9mm
Rear SKF 6004 2RS 'H' size 20x42x12mm
Pre Pro models were 6004 front and rear.
If you can get the bearings with an 'H' suffix this is for a better high friction seal.
sorry thought i'd put it on its 2005 Raga model
Those part numbers you mention are the same as what is called for my 2010 Pro. I can confirm that they are:-
Rear C160001 is a 6004 2RS
Front ME120136055 is a 61905 2RS
