March 23, 201115 yr Hi There Can anybody help. I have broken my kickstart shaft on my JT35 and now need to convert it from a 16 mm to a 18 mm. Has anyone done this conversion - if so all information would be much appreciated. Information required: 1. The dia of the hole I need to enlarge in the outer casing to accept the new seal and bush 2. The item numbers for the new seal and the new shaft bush Finally will any kickstart arm now fit the 18 mm spline shaft. Thank in advance Wayne
May 9, 201115 yr Sorry I can't help you with the question, but I just broke my kickstart lever on my 16mm shaft and am in need of the clamp and lever. When I pulled the clamp the allen bolt on top busted off, so I drilled it out and when I went to retap it the tap broke off inside. The tap is to hard to drill into and now I'm stuck. Is your old one available if you still have it? Are you in the US? Thanks ( I hope ) Brandon
May 13, 201115 yr Hi there my U S friends i got a few side casings here and a kickstart shaft from a 2001 280 if any good to uses hope use get it sorted thanks and good luck Andy
