March 23, 201115 yr Hi I've got a 2010gasser and on the back of the airbox is a large rubber covering the full length of the air box. It's got to the stage now where it is falling off as the glue has came unstuck. I've tried to glue it back on with araldite but that hasn't worked. I'm just wondering what all you guys use to glue this rubber on or do you use some small screws and fix it that way? Cheers coxy
March 24, 201115 yr Hi I've got a 2010gasser and on the back of the airbox is a large rubber covering the full length of the air box. It's got to the stage now where it is falling off as the glue has came unstuck. I've tried to glue it back on with araldite but that hasn't worked. I'm just wondering what all you guys use to glue this rubber on or do you use some small screws and fix it that way? Cheers coxy Araldite won't work in this situation. Try silicon seal.
March 24, 201115 yr I have broken several airboxes.... Contact adhesive works very, very well. Apply as per the instructions on the tin or tube.
March 24, 201115 yr grip glue works a treat. i use that then when it's dry and set seal the edge with silicone. lasts a good while too.
