06 Rev 3 Rear Break Bleeding
I have recently bought a 06 Rev 3, Im in the process of bleeding the rear break. Can any of you guys tell me if there is supposed to be a resivoir in under the rear mudguard, as mine just has the hose with a bolt in the end. Will this mattrer or would i be best with one on.
Regards
Marty
yes there should be one and yes it matters, as your pads wear fluid is taken from the reservoir to fill the void behind the caliper pistons
Thanks guys i'll get one sorted. Just while we are on the topic any tips on bleeding the rear break????? :(
Marty
