April 15, 201115 yr getting a new clutch pack from buxton either tomorroww or monday as clutch slipping on the 327 1992 , changed the master cylinder and new piston in the slave all working fine but slipping , looking at the plates they are well worn and not much meat left . my question is this , do i need to soak the plates in gear/trans fluid overnight before fitting? i have heard of people doing this? regards jon
April 15, 201115 yr getting a new clutch pack from buxton either tomorroww or monday as clutch slipping on the 327 1992 , changed the master cylinder and new piston in the slave all working fine but slipping , looking at the plates they are well worn and not much meat left . my question is this , do i need to soak the plates in gear/trans fluid overnight before fitting? i have heard of people doing this? regards jon Jon, A lot of the new materials don't need it but I still do it out of habit, it won't hurt anything. Any initial adjustments after the clutch is installed will probably be more accurate compared to installing the plates dry. Jon
April 16, 201115 yr Author Jon, A lot of the new materials don't need it but I still do it out of habit, it won't hurt anything. Any initial adjustments after the clutch is installed will probably be more accurate compared to installing the plates dry. Jon Thats great , thanks for the info. kind regards Jon
