April 25, 201115 yr Is it possible to alter the way the clutch bites at all? I'm looking for a softer progression point from no-drive to drive, I think the finger height affects this but I'm not sure. Thanks for any pointers! Edited April 25, 201115 yr by Gronno
April 25, 201115 yr Clutch finger height does adjust it out to 19mm or just move you lever father away from the grip. Try the lever method first much easier no taking apart anything good luck Dustin
April 26, 201115 yr Author Thanks Dustin, I think we've got a crossed wire though, I'm refering to the wee steel fingers inside the clutch pack, not my own pinkies I appreciate the input though!
April 26, 201115 yr You can switch to a softer spring - perfect for the 200 as the std spring is made to hold a 300 and way stiffer than it needs to be for a novice rider looking for a nice slow progressive action. easier to pull too! http://www.jackscycles.com/lpse.htm
April 26, 201115 yr Thanks Dustin, I think we've got a crossed wire though, I'm refering to the wee steel fingers inside the clutch pack, not my own pinkies I appreciate the input though! Nope no crossed wire adjust the steel finger to the 19mm height and it will produce a more progressive feel if you adjust them down to 16.5mm it is more on off feel http://www.youtube.com/watch?v=336BDbcZEMM He explains it perfectly good luck Dustin
