May 31, 201115 yr hy ive run out of tyre soap and need my new tyres on asap is there anything else i can use as tyre soap regards ste
May 31, 201115 yr I've used heavily diluted washing up liquid in a hand spray bottle for years with no adverse effects - apart from a clip round the ear when the missus finds out I've been nicking the stuff from the kitchen!!!
May 31, 201115 yr Author I've used heavily diluted washing up liquid in a hand spray bottle for years with no adverse effects - apart from a clip round the ear when the missus finds out I've been nicking the stuff from the kitchen!!! perfect ill try that cheers
May 31, 201115 yr If you use washing up liquid make sure you wash as much of it off after using it as it will corrode your wheel over time. Better to use proper tyre soap.
June 3, 201115 yr WD-40 works great You guys not using proper tyre soap, are you actualy keeping the tyre on the rim?
June 3, 201115 yr Can't beat neat fairy liquid also sticks the tyre to the rim when dry, never had corrosion problems been using it for years,it also does the dishes lol.
