asaf Posted June 8, 2011 Share Posted June 8, 2011 Hi Guys, some knows the standard suspension settings (numbers of clicks) and the SAG for Gas Gas 280 TXT pro model 2004? Thanks, Asaf Quote Link to comment Share on other sites More sharing options...
nzralphy Posted June 8, 2011 Share Posted June 8, 2011 You need to set your bike to 1/3 sag wen you stand on it (with your riding gear). Be mm accurate! Then adjust damping to suit riding style preferences... Quote Link to comment Share on other sites More sharing options...
asaf Posted June 9, 2011 Author Share Posted June 9, 2011 You need to set your bike to 1/3 sag wen you stand on it (with your riding gear). Be mm accurate! Then adjust damping to suit riding style preferences... Thanks, do you know the standard setting for the forks (if there is any) Quote Link to comment Share on other sites More sharing options...
nzralphy Posted June 9, 2011 Share Posted June 9, 2011 Thanks, do you know the standard setting for the forks (if there is any) No. Front and rear damping is put there to help maintain traction. In the garden..... Try setting the rebound damping so that it just takes the bounce out of the springs.... Stand on the bike an bounce the bike up & down evenly... then make adjustments..... try all the settings to get a feel for how they work. Quote Link to comment Share on other sites More sharing options...
