TY175 Coils.
Has anyone recycled their lighting coil as an ignition source coil?
Reason I'm asking is the PO ran without a flywheel cover gasket and everything on the stator plate looks minging.
I have a couple of lighting coils on my other TYs which are redundant and I'd like to use as a cheap fix.
Thanks, Jonny.
Never tried it to see what would happen but the lighting coil output would be completely wrong for use on the primary HT coil. Give it a go..probably will burn something else out though. Go electronic its well worth the
