middle silencer
hi how do you get the middle box out of a 315 i had a quick look before it looks a bit of a pain help
It is a real pain in the ar*e!!
you have to loosen or remove the front pipe (so that ther is some play to wiggle the mid boxloose), remove the rear wheel, airbox, shock absorber, and then slide the box out of the rear - you can leave the carb attached as the rubber mount will allow some play to get it by.
As I said at the beginning...a real pain in the ar*e......but very satisfying one rfemoved and repacked (assuming that is what you are doing)
Good luck!!
thanks mate yes a good de coke needed what a pain
