Beta Drowned?
The young un had an off in a river today :rotfl: Should'nt laugh
Any who's the bike lay down for 30secs 1/4 submerged
When I got to him, picked it up it started no bother
10 mins later after running fine, it died :(
There's no spark
Plug replaced still no spark
When we got home I took off the stator cover and soaked it in WD40 (I dont know if I did good)
It's a 2008 Rev 3 200cc
I aint no mechanic! but any suggestions would be appriciated :thumbup:
Edited by Stevecollie
After reading a few posts re: Stator
I went and got her indoors hair dryer (I dont need one) out :rolleyes:
Up to the garage, and gave the poor wee thing a blow job dry :huh:
Another few "Scoot's" of WD and a new spark plug :)
2 kicks later after a pampering it burst into life :thumbup:
Panic over :blush:
Did you check the airbox? Empty it and clean the filter.
Stand the bike on the back wheel and see if any water comes out the exhaust
Strip and clean the carb thoroughly
Change the oil
It's not the water that's the problem but the grit and silt in the water so you need to do a proper clean up job :thumbup:
Edited by Kinell
...and, more importantly, return that hair dryer or you will be in BIG TROUBLE... :chairfall:
I dumped my sherco in the creak once,pulled the plug and tipped it upside down, pumped the water out of the cylinder. Cleaned the air filter with some 2-stroke fuel and finished the event. Did not touch the motor for 2 years. Was running pretty rough by then, Split the cases to fit some new Crank bearings and seals and I got a surprise. There was dirt/silt caked into the corners of the intake, the rings were blowing by so bad there were scorch marks on the cases UNDER the crank bearings. I think it was recycling the fuel. :D
Hope yours is not as much trouble.
I thought Sherco's came from the factory like that! ^_^
Change the oil
Thanks for the tip, I'll give it the once over tonight :thumbup:
I think I left it up in the garage :rolleyes: she'll go out this morning looking like she's been dragged through a hedge backwards :angry:
No change there then :rotfl:
That is only because Sherco is very concerned about the environment. You see if the fuel/exhaust mix recirculates and burns a second time there is less emissions produced and better fuel economy. :D
My bike after being fixed really sucks down the fuel now. But it runs SSSOOOO MUCH better now.
