June 28, 201115 yr hiya could any one have an idea on how to remove the BOTTOM yoke on the 2006 beta aye have removed top bolt the yoke and the other bolt then the cover n washer but there is a what looks lika a spacer on top off the tapperd barring there is no other bolt at bottem off yoke and this what a amagen washer is stuck on SOILD HELPPPPPP PLZ
June 28, 201115 yr If you have removed the threaded ring then a tap with a hammer (soft faced) should move the stem.
June 28, 201115 yr Author the threded ring the one ontop off the barring a tried taping this aswell but no luck
June 28, 201115 yr If you can see the bearing itself then you have removed everything necessary. If it does not respond to sensible use of the hammer then something is wrong but I can't think what.
