July 2, 201115 yr Check the post Beta Drowned Not such the quick fix after all The bike took a dunking last week (2008 rev 3 200) It died after about ten mins of the soaking I'd thought I'd fixed it (with a hair dryer & wd40) It appears not so Theres No Spark....................................... How do I check the coil and the stator? I'm no mechanic but I can do the rudiments But when it comes to electricial Cheers in anticipation Edited July 2, 201115 yr by Stevecollie
July 2, 201115 yr Have you tried disconnecting the kill switch, its possibly full of water if it hasnt been dried out. That could stop it from sparking.
July 2, 201115 yr As in just pull it apart If yes! I've done that and scooshed it with WD I think its the black and white cable from the switch, just unplug the connector and it should stop it from earthing out. Its the first place I would try before the coils or cdi.
July 2, 201115 yr Author I think its the black and white cable from the switch, just unplug the connector and it should stop it from earthing out. Its the first place I would try before the coils or cdi. Ok did that! I'm now getting a spark But it aint bursting into life yet (nearly once)when I hit the side of the carb with a spanner So I drained out all the fuel (Tank & Carb) Replaced with new But still no joy I'll strip the carb in the morning & see what happens Thanks
July 2, 201115 yr I'll strip the carb in the morning & see what happens If it gets you uummm ahem "excited" we would appreciate not knowing what happens. I would imagine there is a motorcycle counterpart to this guy??
July 2, 201115 yr Author If it gets you uummm ahem "excited" we would appreciate not knowing what happens. I would imagine there is a motorcycle counterpart to this guy?? Who's been talking Before I strip the carb I'll slip into somthing more comfortable
July 3, 201115 yr Who's been talking Before I strip the carb I'll slip into somthing more comfortable
