July 12, 201115 yr Hi Barfy your suspicion would be correct... i would expect the clearance to be somewhere between .002" and .004"maximum depending on design etc. Converting that to metric, thats .05mm to 0.1mm max. All things considered, the piston to bore clearance 0.58mm is unusable. just checking, are you measuring the piston skirt below and at right angle to the gudgeon pin? Dom
July 12, 201115 yr Author Hi Barfy your suspicion would be correct... i would expect the clearance to be somewhere between .002" and .004"maximum depending on design etc. Converting that to metric, thats .05mm to 0.1mm max. All things considered, the piston to bore clearance 0.58mm is unusable. just checking, are you measuring the piston skirt below and at right angle to the gudgeon pin? Dom Thanks Dom and all, Panic over. Using my callipers the piston is about the same measurement on the skirt below and at right angle to the gudgeon pin. The top of the piston seems to
