September 13, 201115 yr Hi I,m after bar risers for a 2011 300 Pro, just wondered whats available, i,ve seen the S3 type but they don,t look like they raise them that much and being 6ft 3" i want to notice the differance, the clamps are the hinged type so most of the mx one,s won,t fit by the looks of it.
September 13, 201115 yr Buy longer bolts and make some spacers for underneath out of blocks of alloy... also it means that you can start with 15mm and work downwards. I have tried the S3 and you can notice the difference straight away (although only 6'2").. I found that they were really good until I took them off and it felt even better after taking them off, ride standard settings now.
