October 10, 201115 yr I've drained the oil and added 600ml of new. It appears to be over filled as when I remove the level check bot by the brake pedal oil comes out. Will it find the correct capacity if I let oil come out until it stops ? An earler post says not as the engine is mounted at the wrong angle for this to work. Any advice welcome
October 10, 201115 yr I've drained the oil and added 600ml of new. It appears to be over filled as when I remove the level check bot by the brake pedal oil comes out. Will it find the correct capacity if I let oil come out until it stops ? An earler post says not as the engine is mounted at the wrong angle for this to work. Any advice welcome Will it find the correct capacity if I let oil come out until it stops ? I do this and it's fine, I lean it against a wall so there is slightly more in...
