October 17, 201114 yr hi all the bottom nut on the yokes the one that holds the bearings in anybody know what size c spanner id need to tighten it up? i know you can use a big screwdriver but ive just had the yokes painted. and dont want to damage it or the nut?
October 17, 201114 yr The overall diameter of mine is around 62mm so I reckon that one of these might do the job:- http://www.amazon.co.uk/Draper-68857-32-Adjustable-Wrench/dp/B0002GV128/ref=sr_1_7?ie=UTF8&qid=1318875452&sr=8-7
October 18, 201114 yr The overall diameter of mine is around 62mm so I reckon that one of these might do the job:- http://www.amazon.co.uk/Draper-68857-32-Adjustable-Wrench/dp/B0002GV128/ref=sr_1_7?ie=UTF8&qid=1318875452&sr=8-7 Shouldn't you just be able to do it by hand!
October 18, 201114 yr Author Shouldn't you just be able to do it by hand! hi thought it had to be abit tighter than hand tight cheers bondy
October 18, 201114 yr Author The overall diameter of mine is around 62mm so I reckon that one of these might do the job:- http://www.amazon.co.uk/Draper-68857-32-Adjustable-Wrench/dp/B0002GV128/ref=sr_1_7?ie=UTF8&qid=1318875452&sr=8-7 yes one of them should do it cheers
