October 25, 201115 yr hey all , im pretty sure the front wheel bearings the same as the rear, i jus replaced the two rear bearings the weekend and figured for the sake of 6 bucks each i might as well throw two in the front to maker tight as a drum front n rear..i jus cant seem to find any front lots or rear so i figured i would ask to double check to see if any of you guys know for sure if the front the same as the rear thanks for any info guys , cheers ! anthony
