November 24, 201114 yr hi i have a gas gas 125 txt pro 06 and the kick-start hits the peg so i was wondering if anyone knew if a beta grubber kick rubber would fit
November 24, 201114 yr Sounds like either the peg, peg mount or kick start are bent in some manner. Check them against another Gasser and see.
November 24, 201114 yr hi i have a gas gas 125 txt pro 06 and the kick-start hits the peg so i was wondering if anyone knew if a beta grubber kick rubber would fit Funny as it sounds, the kickstart is supposed to hit the peg. The peg is the limiting factor in the kickstart shaft rotation. My 280 Pro kickstart has been hitting the peg for 10 years, no problem. Jon
