December 8, 201114 yr Anybody have any idea how to alter the timing on a 2008 rev 4t or is it best to leave it to the experts cheers Neil
December 8, 201114 yr You can't. Well i think anyway. (covered my ass there) flywheel is keyed to shaft, pickup doesn't move and neither does stator. only thing you could do would be to change the CDI unit. THIS kit has a different CDI. Edited December 8, 201114 yr by Chris Morris
December 8, 201114 yr What are you trying to achieve by adjusting the timing? is it running rough or do you want to calm the bike down abit?
December 8, 201114 yr Gday, that is a fuel mixture issue, it's running too rich. Your Carb needs adjustment - I think there are a few threads on this already so have look through and you should find the cure. Cheers, Stork
December 8, 201114 yr Author Carb has all standard jets and mixture screw is four turns as per Lampkins and they now reckon it's the cdi unit but they no longer have a mechanic
December 8, 201114 yr just out of interest could you try it in the dark and check coil and lead for arking out
December 8, 201114 yr personally i'd remove the carb, thoroughly clean it and all and check the adjustment/needle. my experiance from the sealed cdi unit is the either work or dont. have you check the pins on the cdi unit plug. i know it's a rev 4t but on the evo they are more vunerable to water ingress and corrosion and that can make it run rough.
December 9, 201114 yr The CDI will work or stop - it can't do in between. Check that the choke plunger is seating properly and the float Valve is working properly
