December 28, 201114 yr i have a sherco 290 2006, im new to all this, ive been out ridding tody and sometimes when you pull the clutch right in it still bits a bit, and when you let the clutch out it wines ! any help
December 29, 201114 yr i have a sherco 290 2006, im new to all this, ive been out ridding tody and sometimes when you pull the clutch right in it still bits a bit, and when you let the clutch out it wines ! any help Difficult to quantify here, as some drag and possible whine is normal, yet excessive drag or whine may not be. This could be nothing to worry , but aan evaluation from your local dealer or experienced other may clarify it.
