February 7, 201214 yr Just installed a flywheel weight to my 280 pro fitted the gasket spacer, but the gear change lever clashes with the flywheel cover. I can fit the lever low pointing down at around 8 o clock position or high at the 11 o'clock position neither very good. Anyone no of a better fix or if another type of lever does the job. If the lever had been steel rather than alloy you could heat it up and bend it. Regards mal
February 8, 201214 yr Just installed a flywheel weight to my 280 pro fitted the gasket spacer, but the gear change lever clashes with the flywheel cover. What year is your bike? I'm planning to install a FFW on my '02 280 pro soon, so am curious as to what folks recommend.... Edited February 8, 201214 yr by PurpleBeast
February 8, 201214 yr I found that the genuine GasGas gear lever is useable with a flywheel weight, but the fancy looking pattern jobs are not.
February 8, 201214 yr You can bend it if its hot enough.Rub some soap on the place you want to bend it,warm it up[i use the gas ring on the oven when the boss is out shopping]when the soap goes black its the right heat to bend.You don't have long before its lost the heat,repeat the process rather than bend it too much and snap it.Sounds like witchcraft but it works
February 8, 201214 yr i had same problem with my 2010 pro, grip spline end in vice gently warm lever with blowtorch &gently ease lever outwards, remembering it is alloy not too much heat & its gently gently do not over do it, does not need much to clear casing
February 8, 201214 yr You can bend it if its hot enough.Rub some soap on the place you want to bend it,warm it up[i use the gas ring on the oven when the boss is out shopping]when the soap goes black its the right heat to bend.You don't have long before its lost the heat,repeat the process rather than bend it too much and snap it.Sounds like witchcraft but it works How long do you recommend on an induction hob . Mine fitted fine and with the standard gear lever. Yet to try it on me 250 as its way to snappy compared to me last 300.
February 8, 201214 yr Author What year is your bike? I'm planning to install a FFW on my '02 280 pro soon, so am curious as to what folks recommend.... It's a 2003 model, sorts the bottom end out a treat.
February 8, 201214 yr I just fitted the lever back on the splines a little further out, but still with plenty of depth so the clamp has something to grip. Sounds to me like your lever is bent or non-standard. Cheers, Wayne.
February 8, 201214 yr Heat it till the soap just chars, repeat the heating after bending is finished to stress relieve / anneal it.
February 8, 201214 yr Sounds to me like your lever is bent or non-standard. Given where the lever is located, it would be easy to end up bent in a bit from tip overs/crashes, so this makes sense. Mine looks like it'll probably rub just a bit once I get the FWW spacer in....but figure I'll see when I get it installed, and if pulling it out on the splines a tad doesn't work, I'll do the heat/bend thing, since it won't need more than a millimetre or two of extra clearance on my bike. The soap as temperature indicator is a cool idea. Good advice guys..thanks.
