February 17, 201214 yr Just bought this rim and on taking the tyre off I found the below. Is it scrap or useable? (my first use of photobucket, so hopefully the pics are accessible)
February 17, 201214 yr Sorry to say its more than likely that its scrap. Get a wire wheel on a drill & start cleaning around the valve hole. If you get to solid metal straight away you should be ok to use it. You may find its all oxide with 0.5mm of solid ally holding it together. Mine was like this, i hit it with a hammer & it collapsed. Imagine that happening just as you do a nice drop off.
February 17, 201214 yr Just bought this rim and on taking the tyre off I found the below. Is it scrap or useable? (my first use of photobucket, so hopefully the pics are accessible) Scrap !
February 17, 201214 yr Author Also, what are the offsets for the rear wheel aaaand I'm looking at a Talon hub. Are the disc or drum?
February 17, 201214 yr Ah well, at least I have a hub and Z's if I can get it apart. best thing to do is buy a tubeless rim from central wheels
February 17, 201214 yr Author That's a possibility I've looked at. I'd like a tubeless rear wheel. SM products do a set of Z's for
