A Bit Of Help Please
Hi, how are you all doing? I just striped all the lights and horn off my 2003 Montesa 315r, It was running perfect before I went at it, I have only unplugged connectors but now I have no spark any help would be great. cheers
if you had a kill switch on the the original handlebar switches and dissconnected it it is probably that
Have you reconneted the two plugs where the old loom came out. I think 2 white multi plugs under the tank 1 male and 1 female -can't be exact as its been a long time.
The lighting loom forms a full circuit when in place - if you have disconneceted it all the it will be obvious which plugs need to be reconnected.n
cheers lads, i got it sorted, I unplugged something that did'nt want to be unplugged.
