steve_e Posted May 17, 2012 Share Posted May 17, 2012 Just a quick tip, if you have a tubeless tyre and its leaking from the rim through the spokes, Nip down Halfords and buy a can of tyre weld. Blow your tyre up with it, ride the bike around for 5 mins then let the tyre down to your usual pressure and you should never have a problem with the rim leaking again. I have used this on every bike with a tubeless tyre and every time I change a tyre. This is more effective than stripping you tyre off and silicone sealing the rim band. 1 can of tyre weld will do around 5 tyres and is reuseable (I am still using a can I brought last year) It can be usefull for sealing a puncture too during a trial. Quote Link to comment Share on other sites More sharing options...
