March 10, 201214 yr I spent some time putting around the yard last night and the bike ran perfectly for an hour or so. I attempted to go for a ride today. When I got to the trail head as usual I went to start the bike to warm up. It started on the second kick like it normally does, but only ran for a few seconds and died. I tried resetting the ECU and disconnected the kill switch to no avail. When I got the back home I pulled the plug and I can't see any spark I tried a new plug and still no spark. The plug is pretty dry after a few kick overs and there isn't much fresh gas smell coming out of the plug hole when checking for spark. It was raining today and I transport the bike on a hitch hauler so I thought it might be water intrusion somewhere. I've gone through all the connectors around the R/R stack and coil. There's wasn't an excessive amount of water anywhere. the center pin of the BAS plug was a little corroded so I cleaned it up. I jumpered the outer 2 leads of the BAS and it didn't seem to make any difference. I pulled the BAS and is does rattle a little bit, but it also sounds like it filled with liquid. Is that normal? Am I jumpering it correctly Red/white to Green? Any other thoughts of what might be the cause? Thanks.
March 10, 201214 yr It could be the fuel pump. I just went through this with a friend. we swapped tanks and it fired 2nd kick.
March 10, 201214 yr It could be the fuel pump. I just went through this with a friend. we swapped tanks and it fired 2nd kick. ...........and they arn't cheap!!
March 10, 201214 yr Author I got a chance to dive further into troubleshooting today. He good news is the fuel pump runs with an external power source. WIth everything connected except the R/R it still have no spark or squirt. I pulled the injector to verify there was no fuel. Going through all the steps in the manual everything checks out accept the pulse generator which reads as an open circuit. I haven't pulled the side cover yet to check the wiring, but that is the next step. Is there anything else that would cause no spark and no fuel? Is there a flow chart anywhere of how the FI system on there bikes work?
March 30, 201214 yr Author Thankfully this was easier and cheaper to fix than at first thought. It took longer to get the parts in hand than it did to actually get the bike rideable again. My pickup coil was the reason I wasn't getting spark or fuel. I assume the ECU didn't know the engine was even turning when I would kick it over. The only way to replace the pickup coil is to buy a complete stator assembly for $250-300. I really didn't want to have to do that since the knew the stator was good. I started scouring sources online for pickup coils only to find out there weren't very many. I did find this spec list for Eletrexworld.co.uk http://www.electrexworld.co.uk/acatalog/Online_Catalogue_Pick_up_Coils_160.html that pointed me in the direction of what other bikes might have the same pickup. It ends up KTM sell their pickup coils as separate units for $68 new. Being a cheap ******* and not wanting to blow $70 on a hunch I found one on Ebay from a 04 450 exc. Once I had the KTM coil in hand it was almost identical to the stock unit except for the shape of the mounting plate to allow clearance for the stator wire hold down. A little file work and everything fit together perfectly. 2 kicks and it runs like a champ If anyone ever has this issue the KTM part that I used is 59039034000 PULSER COIL KOKUSAN 4K3-A/B which is used on almost all KTM singles from 98-05. I want to thank Dennis at OverlandTrial.biz and Don a Cascade Motorsports in Mission BC for letting me pick their brains and come to the conclusion that it was only the pickup coil and not something more complex.
