Brake Pedal Push Rod ?
Can anyone point me in the direction of where I can buy a rear brake pedal push rod ??
The original pedal was snapped so ordered another, now I notice the original push rod doesn't detach from the broken lever, and I can't find a push rod from where I got the new lever.
Thanks in advance.
I would just grind or drill one end of the rivet away, drive out the remaining part and replace it with a hitch pin and cotter pin or bolt and self locking nut depending on clearance. That way if you need to, you can simply unbolt it and move it to another pedal.
I bought a nice red one from motomerlin and it came without the pushrod too. I drilled out the end of the rivet on the old and installed it on the new. The new one did come with the rivet I needed though.
