March 20, 201214 yr Hi Bought an 07 txt250 Engine had an annoying "rattle" turned out to be 2 bearings knackered in gearbox Put everyithing back together new bearings in gearbox new piston new clutch etc. Started bike up...there is an annoying rattle coming from the clutch area...when you engage gear the noise goes...when you pull the clutch in the noise is still there it only goes when you engage gear!! We've checked the clutch basket etc and everything seems to be fine.....any ideas before we strip it down again? arghhh!! Thanks Steve
March 20, 201214 yr Author No there was We had used wrong oil (AF) as it was a dph clutch...all running fine now
March 21, 201214 yr Author Bike is all fine now...never use ATF oil in the gearbox no wonder so many gassers make a noise!!
March 21, 201214 yr If you have a terrible rattle constant problems & bits falling off regular dont worry this is gas gas ownership....the remedy is buy a beta
March 21, 201214 yr Author My mate foloows me round with a wheelbarrow picking all the bits up it's not a problem really
March 22, 201214 yr My mate foloows me round with a wheelbarrow picking all the bits up it's not a problem really Sounds like you're sorted but...It's not a Gas Gas wheelbarrow,is it?
