March 25, 201214 yr My Cota 247 has had quite a few bar bending spills - and now even a light fall results in a bend so I I think they are past their use by date. Can I get some suggestions on replacements. I do like the original wide bars they are approx 820 mm (32 inches) and I would prefer something without the cross bar support so as to keep the original look.
March 25, 201214 yr Andrew KT250 bars from fred&debs NZ are a good quality old fashioned bend and reasonably priced $45?+post ( thanks David Lahey for originally suggesting them) they are the bars on my 325 Sherpa that you have ridden, can't measure them at the moment as I'm back in Wilcannia but will when if I get back
March 26, 201214 yr Author Thanks Ross (and David) yes those are nice wide bars so I have ordered them $63.81 delivered
March 26, 201214 yr What rise feetupfun? About an inch less than the ones on my M49. You can measure them in the time-honoured Reginald way if you want. There is a new set not fitted to anything yet.
April 7, 201214 yr Author new bars are great thanks Ross and you may remember always had a flat spot in the top end - new muffler and flat spot is gone
