Cota 200
Hi everyone,
I'm hoping that some of the experts can help!
I have an MH123 frame with a 200 engine fitted. The engine number starts with 29H. The only reference to 200 engines I can find is 29M.
  1. Does anyone know what my 29H motor actually is?
  2. I have a Cota 200 (not MH200) owners manual that states for Castrol TT (which I use) the ratio is 4% (25:1). I have seen posts on here that state 40:1, 50:1 and even 80:1. Does anyone know the definitive answer to the petrol/oil ratio? Mine does smoke a lot!!
Any help greatly appreciated.
Thank you
Ash
50:1 FOR FUEL MIX
29H DENOTES MONT/HONDA 200 ENGINE - 64MM BORE
28H SHOULD BE 125CC - 54MM BORE
200CC TOP END WILL FIT ONTO 125CC
Thanks very much, 50:1 it is then.
Does anyone know the correct jetting for this? It has a Mark 2 Amal carb with standard airbox and filter.
Thanks
