April 4, 201214 yr Hi all, again, Ive read loads of posts about this already but still no idea, I'm wanting to change my oil on my06 txt pro 125, the user manual says atf, so I would of thought that, then I read other peoples posts and not too sure, the oil I can see in the level glass isn't red but not sure what it is, any ideas guys?
April 4, 201214 yr putoline light gear oil i think will be in your bike,but atf dextron 3 is better oil for gas gas gear box 400ml only,you can buy this from millers oils brighouse in bulk 5lts
April 4, 201214 yr Author I can get that no problem but does it matter that I'm putting different oil back in as I heard it could make the clutch plates swell?
April 4, 201214 yr I can get that no problem but does it matter that I'm putting different oil back in as I heard it could make the clutch plates swell? It's the type of oil that matters, not the changing. Type-F ATF seems to work better in the 06' Jon
April 5, 201214 yr yes its spot on for all gas gas pros Apart from if its got an aftermarket DP clutch pack in it..... it will make those plates swell after time and your lever will go stiff...
