April 8, 201214 yr If this should go in the Gas Gas section - appologies and the mods could move it? Got a JTX250 97 with a dead fan, was working ok last time out but I've since had the engine out for a freshen up. The fan switch appears ok and I have an overide switch so I know I've got continuity through that (checked with multimeter) From the rectifier on the red wire which I'm assuming is the live I'm only getting 4v when its running at bit more than tickover, (typical section revs) which doesn't seem right. I've tried for continuity through the fan motor but get nothing - is this right? - this was checking it with buzz on the multimeter, I would think I should be able to test the resisitance through the motor to prove that there is a path but I'm not sure. I put 12v through the fan from the car battery but nothing happened?? Anybody got any advice on checking this out further, don't want to buy a fan if thats not the problem
April 8, 201214 yr You should be able to get a resistance reading through the fan motor. If you have put the fan in a circuit with a battery and it still doesnt run then sounds like its had it.
April 8, 201214 yr Author Yeh I thought i should be able to get a resistance thorugh it, strang ehow it just stopped though, any ideas on the voltage side??? don't want to buy a fan and find out its something else
April 10, 201214 yr Author Stripped it out yesterday and put 12v across it again, push started it and it does run but it feels "tight" so will try to get a new motor.
April 11, 201214 yr Although your fan motor sounds siezed - I went through a few fans because voltage spikes would fry the windings. I ended up putting in a capacitor to smooth out the voltage and since then no fan problems. Edited April 11, 201214 yr by TrialTrial
