April 10, 201214 yr Hi all, before taking the front sprocket off my 349 can someone say if it´s a left or right hand thread. I expect it´s a right hand because its got e retaining clip but i´d rather be certain before maybe tightening it instead of untightening it. Thanks
April 10, 201214 yr Left hand thread, a impact gun is the best way to remove, good luck getting the sprocket off!
April 11, 201214 yr Author Thanks jimbo it does help to ask before starting the job. I´ll bring my compressor and impact drive home from the workshop and have a go at it on saturday.
April 12, 201214 yr The nut will not be a problem, but I suggest to bring a 100mm angle grinder home too so you can cut the sprocket to get it off its taper
