2.9T Jitsie Shock Rebuild/refill Question Please
Hello, fellow plonkers, just an old guy from Ontario Canada with a 2.9T suffering from 'Jitsie-2low-oil'. I have putted around on TLs & TYs for 30yrs and recently bought this 2.9T that some, ahem, maniac mechanic owned. It seemed like a great deal- 1800 CAN$ for an 03 in 2011, despite showing many battlescars. Oddly, I lacked the common sense to spend adequate time evaluating the back end; the PO said it was almost new and it seemed to damp well and did not show any leakage, but of course, after its (to me) maiden voyage, it seems that the rear shock is low on oil- when you first bounce the rear, it takes about 3 hard bumps to get the oil affecting the rebound, then if you continue, it seems to have semi-passable damping. Changing the rebound damper adj collar just makes it harder, but that syndrome remains. The shaft bushing (if that's the word) feels tight and the chrome is perfect, so I am hoping that it simply needs more oil.
The shock, from all appearances, is a Jitsie unit and has a small philips* screw on the bottom of the body, which makes me wonder- Can this shock be refilled, and if so, what weigh of oil would be good? I have lots of tools, taps, even have a few Schrader valve stems with tapered pipe thread interface that could be fitted in that location, if that makes sense. As for now, I can find nothing when googling Jitsie+rebuild here or anywhere else. Any help would be most appreciated.
* I said 'Philips', but would not be the least bit surprised to find that my BYM friend had taken out what was in there and driven a self-tapping sheet metal screw into it! THe spring adj nuts look like someone whacked them with a sharp chisel and a mallet!
Thanks,
JR
Oh my! I think you will need to contact Adrain Lewis(Lewisport USA) as he is the importer and I think he has someone to do them. They are likely pressurized well, so be careful with it. :closedeyes:
http://www.lewisportusa.com/parts_wheels_springs.htm
Edited by copemech
Thanks,
JR
Self-tapping metal screw in a shock, that sounds terrible!
From what I know, Jitsie is marketing a shock that is built by a Belgian company called "TRP Suspensions" so you might have more luck googling this instead. For sure it's rebuildable, I would try to find a local suspension shop for a quote on rebuilding it. If you don't find locally there is Stadium Suspensions near Montreal,QC that should be able to help.
So are you saying it is like a pogo stick? Which is what low oil would do,but you say it gets hard. The earlier sherco suspension always seemed a little `dead` to me.
previous discussion;
http://www.trialscen...-rebuild-in-us/
Also rear suspension usually is the lightest oil you can find and 150 seems to be what I remember for pressure, but it`s been awhile since I messed with one.
Edited by lineaway
Kinda what happens is if they get a little low, with some seepage over time, then you got basically some air then oil. Once you jounce it a bit, they mix, and even though you have bubbles in the oil, you still have damping. Could sound "squishy" as the bubbles travel through the valve? Still works, yet not ideal.
So I suspect the thing may indeed have a bit of seepage over time. Most modern shocks doo have nitrogen pressurization, and I doubt this one any different. Just how it is presurized I am not sure. There may be a port under that screw, yet I never take chances with this stuff unless I know what I am doing. There was a time long ago when I did this type work, yet no longer.
Hi, for someone more local to you contact Jim Jervis at Motoheadz in St Catharines. He is a certified suspension repair guy and should be able to help you out.
Thanks a bunch for all the suggestions- it was partly in jest, what I said about the self-tapper, I certainly hope that is not the case. As for professional help (!), yeah, that would of course be the smart thing to do, but I typically only resort to prof help after I have ruled out my own abilities, and with only PT work now, cash flow reinforces that philosophy. The comment about the nitrogen port under the screw makes sense, and I have seen talk of shops retrofitting other brands with schrader valves to allow recharging. I have nitrogen, good tools and the schrader in hand, think I will cautiously dig in. What was described (bubbly, semi-damped) is exactly what happens! I think there is a distinct possibility that the PO tried to change the oil for some reason by removing this screw and failed to realize the need for the nitrogen charge afterwards. I will post a followup, but thanks again for the suggestions.
JR
What colour is the spring? Jitsie are usually orange (TRP printed on spring), and have a separate damping adjuster ring other than the spring adjusting collar(s).
The standard Olle or Sachs would have a yellow or red spring and not have the damping adj ring.
If the screw is very small it may be a damping needle adjuster.
Jitsie shock has threaded removable top mount - remove with caution.
Olle not considered rebuildable without suspension shop type tools, and addition of Schrader valve.
YMV as without a photo we cannot tell if original or modified.
Google Olle and Jitsie to compare.
:thumbup:
Just a wrap up FYI, and thanks again for the suggestions. What I have learned- It is indeed a Jitsie made by TRP. It is rebuildable. The screw in the bottom of the body is indeed a nitrogen recharge port. It is simply a small rubber plug formed into a threaded holder (which is covered by the small M4 philips screw and Oring) and a suspension shop can refill with a fine syringe fitting on their nitrogen tank for cheap..($20 done at 2-wheel in Guelph ON Canada). An oil change/refill/seal is in its future, but for now, the seal and shaft looked great so I tried this cheap step first. An oil refill (there) starts at $150 and I found that the hacker PO neglected all the linkage bearings sooo badly that they are all badly pitted and needing replacement, so it's coming apart again soon anyways. Bottom line is that with the N recharge, it feels marvellous- nice damping, zero gurgling sounds, and of course, it rebounds itself without he spring. No N leakage from the 'violated' rubber plug so far. Delightful result. <JR
