May 5, 201214 yr hi all ive got a 210 gas gas witch has been sat in my kitchen since last october. i start it up about once a week the oil in the window is a clean red wich oil would this be? or wich is the best oil to use? ive read on other threads that the gas gas clutch ratel is this normal? because my bike does the same but when clutch leaver is pulled in the ratel stops. i do plan on using the bike when i get anougther towbar fited.
May 5, 201214 yr Hi, if its red it is normally , what year is it? The rattle is normal, mine is the same, I changed my oil to 75w light gear oil and that made it quieter
May 31, 201214 yr "...i do plan on using the bike when i get anougther towbar fitted." Are you planning to put a tow bar on your Gasser? LOL. What next? Mirrors and cruise control? Cheers.
