May 30, 201214 yr Hi, I was wondering if anyone had a gear change shaft with damaged pawls going spare??? I've got one sheared off flush!!! and was wondering if I could buy one with damaged pawls (as they normally break if the shear pin doesn't work) I would then make a good one out of the pair. What makes it worse I have thrown a damaged one out a couple of years ago!!!!!!!!!!!!!!!!!!!!!!!!!!! Thanks Ian
