June 6, 201214 yr Hello.can anyone suggest a lever off another bike,trials or mx that may fit the beta as a temporary fix. For an Evo which is the same lever as the Rev. Thanks
June 7, 201214 yr as long as the splines are the same anything will fit as an emergency. It is probaly just as easy to order the right one online. If you order tonight you will get it saturday morning in the post.
June 7, 201214 yr Author Yes,I have orderd the correct beta one but just wanted a quick fix for today that I could find in a local non trials shop.an old steel one sawn and bent did the trick.
