June 20, 201214 yr hi is there any way of stopping the rear tyre rubbing the silencer on 2005 txt 280 pro
June 21, 201214 yr You can loosen all the fasteners on the exhaust system and then pull out on the tip of the final silences and tighten all fasteners. Sometimes using a couple of spacers (washers) to space the mid-muffler top tab out where it mounts to the upper shock bolt helps. Jon
