Rev 3 Clutch Master Cylinder Help.
Mine has broken where the lever bolts in. Gutted!!!
The lower tab has snapped clean off so I need a replacement.
New ones are £87.00!
Anyone know of a second hand one floating around or should I bite the bullet and replace the whole assembly and get anoth 5 years or so out the new one?
New one fitted last night. All working as normal.
£87 not bad when you think I now have a spare lever, seals, plunger, cap, diaphram, lever adjusters, and attachement bracket and bolts!
