August 5, 201214 yr What is the best modification, new part or adjustment you have made which has made the best and biggest gain? New front section pipe? Shock? Suspension set up properly? Tyres? Wheels? Anything at all really which has made a noticable difference for the better.
August 5, 201214 yr Not the most practical answer but just riding/practicing what you have for 15 or 20 hours week for a few weeks works. Still always keen to find out other folks opinions
August 5, 201214 yr Actually a found the most usefull investment was in a trials bicycle My low speed balance has improved dramatically from just rolling around doing low speed balance and wheel hopping Aside from from that, new tires were surprisingly more supple than the old hard worn ones I took off Surprising how much easier it is to ride when you don't have to concentrate so hard on some of the basics And finally, I bought an Evo, wow, what an improvement
August 5, 201214 yr Bigger footpegs madey twinshock much easier to ride. Best mod ever goes to the Rekluse clutch for the YZ.
August 5, 201214 yr reed valves. jetting. gearing. bar position. short levers. slow throttle. rear shock. fork re-build. new tyres. quality chain. clutch modification. ATF. stainless wheel bearings. lighter exhaust. last but not least, ignore the above and buy a new bike.
August 6, 201214 yr New tyres, right bar for my height, mental rehearsal, affirmations, practice and watching videos and real time observation of other riders. Oh and focus on having fun not the results. I use rider evaluation forms and listen to others in my club on advice and try it out with practice. For example - from the evaluation form my last three areas for improvement were: good orientation in the section ; stay loose on the bars; slow down; These came from an observation that I was riding too fast; I was getting 5 s for getting lost and an observer suggested for me to relax [i was getting really tense on the bike].
August 6, 201214 yr LOL, interesting comment on the ride too fast thing, my problem is that I try and ride too slow I'm not good enough for that but it's a habit seem to have developed
August 6, 201214 yr Author Sounds like riding is the way ahead. I'd agree with this as a well maintained bike is a pleasure to ride. The more you ride the more proficient you get (up to a point). I fitted a new rear tyre for a mate at the weekend. The old one had been on his bike for 10 years! It was a very old X11 and not only bald but was like plastic not rubber. His 270txt is now sporting a part worn X-Lite which feels like a water filled ballon in a suppleness comparsion. He reckons it has transformed his bike - I'm not surprised.
August 6, 201214 yr Paying attention to where your wheels SHOULD be going in the section. Trials is a lot, lot harder when you're off line.
August 7, 201214 yr i agree with you all ! Being able to see helps... food and hydration are a must. Think i could do with a non - standard Evo 290. Keep it lit and most importantly , level.
August 9, 201214 yr Quick twist throttle (the white one) on a 4 stroke bike. Easy change, BIG difference. I wonder if bikes typically come with slow or fast throttle tubes now days?
