August 12, 201214 yr I'm looking at an 02 200 Pro model. At BDC, the piston is still about 3/32" above the floor of the exhaust port. Is that normal? I expected them to be close to even.
August 13, 201214 yr Maybe someone has fitted an extra base gasket? this would of rose the cylinder improving it
August 13, 201214 yr I'm looking at an 02 200 Pro model. At BDC, the piston is still about 3/32" above the floor of the exhaust port. Is that normal? I expected them to be close to even. Normal. The port will actually flow better at BDC with the slight down step due to the pattern of flow inside the cylinder. Jon
