Montesa 315R Jetting
I have a 1999 Montesa 315R. I would like to know what good starting point for jetting at sea level is. I can't find anything info on stock jetting in the monty manual or in the forums. I can find specs for Gas Gas 270s with the same Dellorto PHBH 26MM carb on the GG usa website..
I have a 135 main
X19 needle 2nd clip from the top
38 slow jet #2
air screw 2,5 turns out.
My plug looks wet and i'm thinking the main should be smaller after seeing the Gas Gas spec in the 18 to 120 range.
Carb Id NoPHBH26CS
Main jet (standard) 135
Slow jet (standard) B46( upper) 46 (lower)
Jet needle clip 3rd from top
Float level 18.5mm
Air screw intial opening 1 turn out
from Montesa manuel 97.>99 315
