Front Wheel
hello all an easy quetion how do i take the front wheel off? am new to gas gas i know on the bultaco i have you have to undo the pinch bolts on one side first before undoing the nut. but on the 210 gas gas pro there looks like theres only pinch bolts on one side. so whats the way you guys do it?
Should be 2 pinch bolts on each side.(4 total)
hi mate thanks for the info. cant see the other side the disc gards hiding them do i undo both pinch bolts on both sides to undo the wheel? and on putting the wheel back on do i tighten the spindel first then the pinch bolts?
To take the wheel out take off the caliper and disc guard then undo the spindle nut then all 4 pinchbolts.
Putting the wheel back tighten the pinchbolts on the brake side to stop the spindle turning just lightly nip the pinchbolts on tthe other side when you tighten the end nut then fully tighten the remaining pinchbolts.
nice one mate its same as my bultaco just didnt want to bugger anything up. ive just sorted me rear wheel put new brake pads in and newrim band :thumbup:
