October 1, 201214 yr Hi all, Still quite new to the trials scene:).Just been out on my new bike down to my woods.. It was so wet and slippery on the hills I could not get up them. How can I stop this? Body position? New tyre? Throttle control? Help greatly appreciated Ben
October 1, 201214 yr add to that tyre pressure and i think youve got everything covered that affects grip.
October 1, 201214 yr Is it your technique? It's easy to blame your bike when others are doing ok. Practice practice practice...
October 1, 201214 yr Yes, practice can help. On the other hand, I've been trying to solve this problem for the past 40 years.
October 2, 201214 yr My nephew had a Scorpa easy once and someone had tightend the rear suspension so much it was useless on the smallest of hills in the wet. . Maybe worth checking if its all free?? Rich
October 2, 201214 yr Hill climbs body position, squat down on the tank = get your crotch close to the fuel tank. This puts pressure on both wheels, keeps front down and weight on the rear. Feels funny the first couple times but it works. Try riding it a gear higher, will probably need a little more throttle but a gear higher will help keep the rear from spinning (less torque hitting the rear tire). Add to that slipping the clutch and this should help. Throttle control + slipping the clutch = good things in mud. New rear tire always helps. Generally riders will drop rear tire pressure to around 2 or 3 psi (depending on tire, rider etc...) for muddy conditions.
